advance pulsar stator cx500
Postby richarde » Sat Dec 08, 2012 2:41 pm
Hi everyone I have a cx500 had the stator rewound but am still getting a weak spark. Have I perhaps put the aps back wrong on my 1 there is a clip of sorts that can move. Can't seem to find out where it should be set to. Hope someone can help........
Thnx
RSA
richarde
Re: advance pulsar stator cx500
Postby Gman » Sat Dec 08, 2012 2:52 pm
Is this a CDI ignition version CX e.g you have a CDI module on top of the rear wheel guard under the seat?
Postby Gman » Sat Dec 08, 2012 4:41 pm
See this thread to check your Plug caps,
viewtopic.php?f=8&t=84
If you haven' already then buy a cheap digital multimeter,preferably with a continuity buzzer like this,
http://www.ebay.co.uk/itm/DIGITAL-LCD-M ... 1e73a3a11f
Then you can check the resistance of the spark plugs caps.Meters are not hard to use once you know a few tricks :)
PS
You can get them from Maplins as well(Open Sundays).
Cheap CDI coils,
viewtopic.php?f=10&t=335
