Mechanical Seal on water pump
Postby winging » Sat Jun 06, 2015 4:14 pm
I have the engine out, '80 CX500, and am trying to replace the mechanical seal, only all 3 seals I have bought are too large in diameter to fit in the case. The bore for the seal is 28mm while the new seals are 28.64mm. That is a half a mm too much for a press fit. Did Honda change the seal?? The old seal case is too far gone to reuse.
Anyone have any in-site to what is going on? I saw a Yamaha pt number listed in another thread, will it fit correctly?
Lady Luck Prefers the Prepared
winging
Re: Mechanical Seal on water pump
Postby Gman » Sat Jun 06, 2015 10:04 pm
You don't need to replace the full seal.Click here,
http://www.pdsrecording.site90.com/cxgl500/Mseal.html
You just have to be careful removing the inner seal.
Also check this forum as well as there's people who have used my system for years.
http://cx500forum.com/
Postby winging » Sun Jun 07, 2015 2:48 am
The metal casing is not usable!
winging
Postby Gman » Sun Jun 07, 2015 10:49 am
Do you mean the rear engine cover or the metal case of the Water pump seal?
Whereabouts are you in the World as well please?
Postby winging » Sun Jun 07, 2015 4:31 pm
The metal case of the seal is not usable. it got beat up removing it. I never thought I would have a problem getting a new one.
winging
