camshaft
camshaft
Postby sinbad » Tue Dec 03, 2013 12:47 am
Hi,
on the engine I am rebuilding, one of the lobes on the camshaft has a small hole and some pitting fearing it could break up I am hoping to get it repaired.Does anyone have advice on this or know a good repairer in the uk.
Sinbad.
sinbad
Re: camshaft
Postby Gman » Thu Dec 05, 2013 11:59 am
It might be cheaper to get a decent one off eBay.You can use any Cx500 or GL500 one.Also they are in two parts e.g an interference fit so you can get them pulled apart and make one good one out of two defunct ones so long as the parts required are good.
I've never used these two engineering companies but worth keeping for reference if that's the way you want to go,
http://www.srmclassicbikes.com/
http://www.sep-kegworth.co.uk/page1.htm
Also check your,"Yellow Pages" as there may be a local engineering company that specializes in engines that can do it.
HTH :)
Re: camshaft
Postby sinbad » Thu Dec 05, 2013 11:53 pm
Thanks for reply and info Kardan,
I didn't know they came apart so that s one option. I will work on your other suggestions and keep my eye on ebay Cheers.
sinbad
Re: camshaft
Postby sinbad » Tue Jan 14, 2014 10:07 pm
http://s846.photobucket.com/user/sinbad ... t=3&page=1 Camshaft re-profiled by Sep Kegworth cost £98 + tax ect
sinbad
Re: camshaft
Postby sinbad » Tue Jan 14, 2014 10:15 pm
sinbad
Re: camshaft
Postby Gman » Tue Jan 14, 2014 10:28 pm
I've tried to have a look at the pictures but no luck :(
But if you are happy with the job then all's well :)
Re: camshaft
Postby sinbad » Fri Jan 17, 2014 9:45 pm
Yes, very happy with the job, tried hard to get it done local but no one doing that sort of thing round here anymore.Engineering and metal fabricators shops disappearing, sign of the times. But we do have good forums. Thanks again Sinbad. :)
sinbad
Re: camshaft
Postby Gman » Fri Jan 17, 2014 11:21 pm
Any problems just let me know :)
