Stumbly, technically speaking.
Postby Tims500 » Tue Mar 19, 2013 8:54 pm
1980 CX500 Deluxe:
Its kind of odd, and at lower RPMs, almost gone with the choke on and cold, giving it a little more throttle smooths it right out.
Any idea's? Thought I'd get some before pulling everything apart.
Tim...
USA 1980 CX500 Deluxe
Tims500
Re: Stumbly, technically speaking.
Postby Gman » Wed Mar 20, 2013 2:04 pm
Do the usual checks in the Carb section for things like carb boot leaks.As it smooths with the choke try making the mixture a little richer.What colour are the plugs after the engine has been ridden.You cannot check plug state on an engine that has just been started or cold.
This is usually a symptom of either a clogged low speed circuit in the carbs or float height/needle valve problem,
viewtopic.php?f=19&t=110
Tip:I take my plug spanner/wrench out with me and stop at a parking spot and take my plugs out from time to time just to check their colour.
