Carb Boot leaks Replacement 8mm Jubilee Clamps/Clips
Postby Gman » Fri Aug 08, 2008 1:29 pm
If the jubilee clips/clamps are getting tired on your Carb intake and air filter boots they can cause bad starting when the engine is warm and high idling etc.At the time of posting the Honda want £4/$8 each if you can find them.
I've found a better and cheaper option.
You can buy a Jubilee clip,"Kit" and make your own to the exact correct lengths you need.They come in the small width 8mm type(Which we need) and the standard 12mm types,
http://www.amazon.co.uk/NS-CT1691-Hose- ... B001MFX4TG
To get imperial sizes to match use this converter,
http://mdmetric.com/tech/cvtcht.htm
5/16" diameter should work.
Re: Replacement 8mm Jubilee Clamps/Clips
Postby LRCXed » Fri Aug 08, 2008 11:40 pm
Nice option! I didn't know they made this. Thanks Shep!
LRCXed
Postby Gman » Thu Apr 01, 2010 10:46 pm
LRCXed wrote:Nice option! I didn't know they made this. Thanks Shep!
Neither did I til I went a huntin' :mrgreen:
Last bumped by Gman on Thu Apr 01, 2010 10:46 pm.
