Correct Carb Cleaning and Idle Jet/Circuit Cleaning
Re: Carb Idle Jets Cleaning "W/ added info update"
Postby Gman » Thu Jul 31, 2008 1:28 am
I didn't spot it either til Randall pointed out :mrgreen:
Postby LRCXed » Thu Jul 31, 2008 1:56 am
All fixed! Thanks again Randall. I hope it didn't confuse to many people. I should have gone back and proof read it for more than typo's! Now when choppers comes back up........... I have to fix that one too. :oops:
LRCXed
Postby Gman » Thu Jul 31, 2008 2:02 am
I hope Chopper's comes back as well.It's good to have more than one main resource in the Western Hemi-sphere :mrgreen:
On a side note.Do these forum pages load fast for you guys across the pond as it's pretty damn fast for me :D
Postby LRCXed » Thu Jul 31, 2008 2:28 am
Oh yes Shep. They load real fast. It's nice to not have to wait or hit X and reload several times. Good server!
LRCXed
Postby Blindstitch2002 » Thu Jul 31, 2008 2:53 am
Pretty smooth sailing over here. Nothing like that other site that comes up Cannot Open. System Error.
Over there I normally hit the post button several times. If it doesn't go in 5 seconds it isn't going to.
Postby mildhog » Thu Jul 31, 2008 5:27 pm
No problem, just a general question. Are the carbs interchangeable between the GL500 and the GL650? Are they the same except for the jets? Thanks.
Arnie in VA
1982 GL500 Interstate
1983 GL650
mildhog
Postby Gman » Thu Jul 31, 2008 5:31 pm
I think there may be a difference in their angle/mounting I reacall.What's the number on the side of the carbs?
Postby mildhog » Thu Jul 31, 2008 5:38 pm
I'll check it out after work today. Thanks.
Arnie in VA
1983 GL650
mildhog
Postby bri-guy-ga » Thu Aug 07, 2008 7:42 pm
Just so I am clear. You don't recommend pulling the seat out? That last couple of pictures was more for illustration purposes I understand.
Great work by the way. I am going to order a set of off ebay and see about doint this myself after I get my bike running decent.
Did you use a regular carb rebuilding gasket set to put it all back together?
bri-guy-ga
Postby LRCXed » Thu Aug 07, 2008 9:12 pm
The last 2 pictures were just to show what was under the needle and seat assembly. NO, do not pull that out.
I DO recommend pulling all the other jets out, including the idle jet that's pressed in.
Carb kits I have been getting from GOERGEFIX'S. Site is in the USA list forum here. Let him know you are on this sight when you call him. The 2 things I don't use if I don't have to is the new needle and the idle adjusting needles. They just dont seem to fit the same. Use the stock ones if they are OK.
LRCXed
