Air Cut off alternatives
Postby Gman » Fri Mar 13, 2009 8:35 pm
Re: Air Cut off alternatives
Postby joshua.brown1982 » Fri Oct 09, 2009 6:27 pm
can you direct me to something that will tell me the proper way the fuel and vacuum tube go to the carb? and what the two connection points are on the inside of the cx 500 1980 carbs?
joshua.brown1982
Postby Gman » Fri Oct 09, 2009 11:05 pm
If you are talking about Carbs with a Vacuum fuel tap and also accelerator pump then my UK Cxs don't have them.Ask again in the general section of this forum,
http://choppercharles.com/cs/forums/
As it's much busier than here :)
