Vacuum Petcock Hose Connections
Postby Blindstitch2002 » Fri Jun 11, 2010 12:57 am
In case you take your tank off and forget how the hoses go when putting it back on here's how it goes.
If you want to bypass the Vacuum Petcock attach a small piece of pipe across these two spigots/pipes and then make a small cap and fit it to over the small spigot/tube on the right hand side carb inlet.It's just around the corner at the front of the Carb.Letter "C" on the 2nd diagram
or
Re: Vacuum Petcock Hose Connections
Postby Ben52 » Mon Aug 15, 2011 11:09 pm
Should the Petcock release fuel when the engine is off? Mine is full flow on reserve, and at a trickle when "on". It shuts off fine. I replaced the bladder already. Thanks!!!
Ben52
