Cx500 Universal CDI coils(Cheap)
Any Mods:Tricks:Customizations:tips.any jobs you have done where you have had to manufacturer your own solutions.Cheap parts to use etc
Re: Cx500 Universal CDI coils(Cheap)
Postby thisman1967gt » Thu Jun 24, 2010 6:14 am
http://cgi.ebay.com/ebaymotors/ws/eBayI ... K:MEWNX:IT
Are the coils I bought, same as pictured above. But, mine came with an additional ground lead and a brass bracket mounted to each side of the coil with a bolt tacked onto the opposite side, facing away from the coil. If you have two of these coils, you can take the stock bracket apart and drill out the two little indentations and bolt the brackets to the stock bracket. Instead of sitting perpendicular to the frame, the new coils now sit parallel to it. I will take pictures in the daytime, as I have no flash. It looks pretty snazzy and you don't need anything to complete it except for drill bits. No extra screws/bolts/nuts/pieces of metal required.
81 CX500C x2
85 CMX250C
thisman1967gt
Postby Gman » Thu Jun 24, 2010 10:23 am
Cool.I look forward to the pictures :)
Postby thisman1967gt » Thu Jun 24, 2010 8:40 pm
And here are the pictures as promised for a neat stock-ish look.
81 CX500C x2
85 CMX250C
thisman1967gt
Postby Gman » Thu Jun 24, 2010 9:00 pm
That really is neat.Can hardly see them.They working ok?
Postby thisman1967gt » Thu Jun 24, 2010 11:16 pm
they work great! Just have to find somewhere for the redundant ground, and clean the stock connectors for the coils. Other than that, Runs super!
81 CX500C x2
85 CMX250C
thisman1967gt
Postby Gman » Thu Jun 24, 2010 11:41 pm
Can you put your location under your Avatar.I like to know whereabouts people are in the world :)
Postby thisman1967gt » Thu Jun 24, 2010 11:50 pm
And you don't have to move or fiddle anything to take them out while they are still on the bracket.
81 CX500C x2
85 CMX250C
thisman1967gt
Postby Blindstitch2002 » Sat Jul 03, 2010 3:07 am
I'm thinking of a similar design as soon as my larger tank gets done. Probably a lot less bulky.
Postby plitskin5 » Fri Jun 03, 2011 2:19 am
Hey guys, can I get an updated link, for a guy in the states, or what parameters to search with to find this?
plitskin5
Postby Gman » Fri Jun 03, 2011 2:45 am
http://www.ebay.com/itm/IGNITION-COIL-1 ... 6rk%3D1%26
:mrgreen:
Remember these are only for the CDI engines,not the later Transistor Ignition engines.The CDI box is on top of the Rear guard under the seat.The transistor engines have two,"Sparker" boxes near the battery,
Previous
Return to Tips And Tricks(Inc Cheaper substitutes)
